This guide describes the functions of the Brickstuff 15-Light Color-Changing Light String with Controller. Your kit includes the following parts:
- Mini lighting effect controller with two small buttons, power input, and light string output.
- Light string with 15 color-changing LED lights and expansion plug
- Black cable for connecting the lighting effect controller to a power supply.
You will also need a Power Pack (sold separately) to use this effect controller-- you can use a Brickstuff Power Pack or any 5 volt power supply.
The illustration below shows the details of the lighting effect controller.
To use the effect controller, connect one plug of the black cable to the Power In plug, and connect the other end to your power supply. After a short pause, the Status LED light on the controller will flash several times (see below for the meaning of each flash), and the light string will turn on with the previously-saved settings.
EXTENDING THE STRING
There is a plug at the end of your light string. The lighting effect controller supports up to 60 LED lights, which means you can connect up to four strings together-- just like with real holiday lights. Each additional string (sold separately) has 15 lights, and you can connect each extension string end-to-end.
POWER
Do not connect the lighting effect controller to any sort of dimming circuit or dimmer controller-- this can damage the circuit board. To operate properly, the lighting controller needs a full "on" connection (5V DC).You can use external switches to turn the lighting controller ON and OFF as long as those switches are not dimmers and provide either a fully ON or fully OFF power supply.
USAGE
You can change settings for the light string using the two small white buttons on the lighting effect controller. As shown in the illustration above, these buttons are labeled B1 and B2 on the controller.
Each button has three different functions, which you can access with a "short press," a "double-click", or a "long press".
- Button "Short Press": pressing a button and releasing it quickly
- Button "Double-Click": two short presses in rapid succession
- Button "Long Press": pressing and holding a button for one second, then releasing it
Using these three different types of button presses for both buttons, you can control six different functions.
Your settings are saved even when the power to the lighting effect controller is turned off.
The paragraphs below describe the different settings in detail.
MAIN SETTINGS
These are the settings you will use most often.
A Short Press of Button 1 changes between three different lighting effects:
- All lights solid (all on)
- Lights flash back and forth
- Lights move in a marquee effect (every 3rd light is on)
The blue Status LED light on the lighting effect controller will flash once to indicate a Short Press has been made.
A Short Press of Button 2 cycles through 12 color settings:
- All lights white
- All lights red
- All lights green
- All lights blue
- All lights orange
- All lights purple
- Lights alternating green/red
- Lights alternating blue/white
- Lights alternating purple/orange
- Lights alternating green/red/yellow
- Lights alternating green/red/blue
- Lights alternating purple/green/orange/blue
A Long Press of Button 1 changes the speed of the lighting effect. There are five speed settings:
- 1.5 second delay between updates (slowest setting)
- One second delay between updates
- 3/4 second delay between updates (this is the default setting)
- 1/2 second delay between updates
- 1/4 second delay between updates (fastest setting)
The blue Status LED light on the lighting effect controller will flash three times to indicate a Long Press has been made.
A Long Press of Button 2 changes the overall brightness of the lights. There are five brightness settings:
- 10% brightness
- 30% brightness
- 50% brightness
- 75% brightness (this is the default setting)
- 100% brightness
If you are running your light strings using a battery power source, use one of the lower brightness settings. Even a dim setting will still be highly visible, and setting the brightness lower will allow your lights to run many times longer than using a brighter setting.
ADVNCED SETTINGS
These are optional settings that you won't need to use as frequently-- typically you will only use these settings when changing the configuration of your setup.
Double-Clicking Button 1 will turn the "tree topper" setting on or off. When this setting is turned on, the last light in the string will be a yellow color, and it will always be on regardless of the lighting effect setting. This allows you to mount this light inside a star at the top of the tree and use the last light in the string as the light for the star.
The blue Status LED light on the lighting effect controller will flash twice to indicate a Double-Click has been made.
When power is turned on, the blue Status LED light will flash once to indicate that the "tree topper" mode is off, or twice to indicate that it is on.
Double-Clicking Button 2 will change the number of connected 15-light strings. You don't normally need to change this setting-- the lighting effect controller will run its effects on 60 LED lights regardless of how many physical lights are connected. The only time this setting needs to be changed is when you use the "tree topper" setting (described above).
When power is turned on, the blue Status LED light will flash 1-4 times to indicate the number of 15-light strings connected.
Thank you for purchasing this Brickstuff product! Your support means a lot to our small, family business, and it allows us to wake up every morning and continue doing the work we love: making really cool things to take your models to the next level!
If you have any questions or problems with this product, please send us an
e-mail and let us know how we can help.
