Product Guide: 9-LED Mini Multicolor Light String with 30 Lighting Patterns
Thank you for purchasing this color-changing LED light string at Brickworld Holiday Joy 2024!  We are still finalizing the instructions and will have them completed by December 10.  Please check back then, and thank you again!
    • Related Articles
    • Product Guide: 6-Wide Lightbars with Integrated Effect Controller and Switch
      CLICK HERE TO TRANSLATE Warning to photosensitive users: some of the lightbar patterns use rapidly flashing lights. People who are sensitive to flashing or pulsing lights should exercise caution when using these lightbars to select a lighting pattern ...
    • Product Guide: Lighting Starter Kit for LEGO Aircraft
      CLICK HERE TO TRANSLATE INTRODUCTION This guide describes how to use the Brickstuff Lighting Starter Kit for LEGO® aircraft. This kit was designed to work with all types of LEGO® aircraft-- you can mount it inside of a passenger plane, a cargo plane, ...
    • Control Guide: Brickstuff Premium Lighting Kit for the LEGO Eiffel Tower #10307
      CLICK HERE TO TRANSLATE INTRODUCTION This guide describes how to use the various control systems included with the Brickstuff Premium Light Kit for the LEGO Icons Eiffel Tower (set #10307). This guide is also linked to from the main installation ...
    • Product Guide: High-Efficiency Power Supply Bundles
      CLICK TO TRANSLATE INTRODUCTION This guide describes how to use the Brickstuff line of high-efficiency power supplies. There are five different versions of these supplies, and collectively we refer to them as the SEED-MV (MV stands for ...
    • Product Guide: Automatic Signal for LEGO® Trains
      CLICK HERE TO TRANSLATE INTRODUCTION This guide describes how to build and use the Brickstuff signal and controller box for LEGO® trains. The guide covers both the all-inclusive Automatic Signal QuicKit for LEGO Trains as well as the Automatic Train ...
