The illustration below shows the main parts of the lighting controller.
Connect your power input to this plug. This is a "small" plug
(Pico-size), so you'll need a connecting cable with a small plug. If
you are using a Brickstuff power supply with a "large" plug, we sell
conversion cables and adapter boards on our website.
OUTPUTS
Connect up to six LED lights to these outputs. All outputs are independent of each other. Each connected light turns on and off in a random pattern. Each of the six outputs uses a "small" plug (Pico-size), so you'll need to connect a LED that has a matching small plug. If you are using a Brickstuff LED light with a "large" plug, we sell
conversion cables and adapters on our website.
Here are some things to note about connecting LED lights to the outputs:
- Each output provides enough power to light a single LED light. You can connect more than one LED light to an output (using connecting cables or adapters)-- there is no danger of burning out or damaging the lighting controller by connecting too many LED lights to any single output. Note, however, that the power will be divided by the number of LED lights you have connected to a single output (for example, connecting two LEDs will divide the power between them and make each LED light half as bright as it would be if connected by itself).
- If you connect a high-power LED light or a LED filament light to an output, those LED lights will be very dim: these kinds of LED lights are designed to use many times the total power output provided by a single output on this lighting controller. Again, there is no danger of damaging the controller, but your lights will be very dim or may not light at all if using high-power LED lights or LED filaments.
- If you want to connect your own LEDs to the outputs in a DIY configuration, we sell individual cables with Pico-size connecting plugs on our website in the DIY section. You can purchase six of these and connect any LEDs you want for marquee effects. Since the lighting controller delivers a fixed amount of current to each output, no current-limiting resistors are needed regardless of the voltage LED you are using. This greatly simplifies DIY setups using these lighting controllers.
POWER LED
The power LED light will be green when power is connected to the lighting controller.
STATUS LED
The blue status LED light flashes to show the current setting for the marquee effect. More information is below, in the USAGE section.
The button is used to change the setting for the delay interval for the marquee updates. More information is below, in the USAGE section.
OTHER PLUGS
There are other plugs on the lighting controller: one marked OUT and one marked SENS1. If you are connecting additional lights to the controller, you will use the OUT plug, but the SENS1 plug is not used on this controller. Leave this plug disconnected (do not plug anything into the SENS1 plug).
USAGE
Once the lighting controller is connected to power, its green Power LED light should turn on. If this LED light does not turn on, check your power supply source. The lighting controller is designed to be operated from a 5V DC power source.
Do not connect the lighting controller to any sort of dimming circuit or dimmer controller-- this can damage the circuit board. To operate properly, the lighting controller needs a full "on" connection (5V DC).
You can use external switches to turn the lighting controller ON and OFF, as long as those switches are not dimmers and provide either a fully ON or fully OFF power supply.
When power is supplied, the onboard Status LED light will blink 1-4 times to indicate the setting for the dealy interval beween marquee updates:
- One blink: 100 ms between pattern updates
- Two blinks: 150 ms between pattern updates
- Three blinks: 350 ms between pattern updates
- Four blinks: 500 ms between pattern updates
After indicating the current setting for the delay interval between marquee updates, the marquee lights will turn on.
During normal operation, pressing and releasing the button will cahnge the selected setting for the delay interval. The onboard Status LED light will blink 1-4 times to show which setting for the update interval is now active. See above for the update time interval settings associated with 1, 2, 3, and 4 blinks of the onboard Status LED light.
If you press the button when the delay time interval setting is at 4 blinks, it will loop back to 1 blink.
Your settings are stored in memory and preserved even when power is turned off.
EXPANSION
Using Brickstuff BrickPixel™ Driver Boards, you can add up to 48 additional LED lights to the marquee effect controller.
